Learn how to automate the enrollment of Thinkific users using Pabbly Connect and FlexiFunnels with this step-by-step tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start enrolling Thinkific users automatically, you need to access Pabbly Connect. This platform is essential for creating workflows that connect different applications seamlessly.
Begin by visiting the Pabbly website and logging into your account. If you are a new user, you can sign up for free, which gives you access to a limited number of tasks each month. Once logged in, navigate to the Pabbly Connect dashboard where you can create new workflows.
Once you are in the Pabbly Connect dashboard, click on the blue button labeled ‘Create Workflow’. This is where you will set up the automation between FlexiFunnels and Thinkific. using Pabbly Connect
- Choose a name for your workflow, such as ‘Enroll Thinkific User on FlexiFunnels Purchase’.
- Select the folder where you want to save the workflow.
- Click on ‘Create’ to proceed to the workflow window.
In the workflow window, you will set a trigger and action. The trigger is the event that starts the workflow, while the action is what happens in response. In this case, the trigger will be a new purchase in FlexiFunnels.
3. Setting Up the Trigger from FlexiFunnels
To set up the trigger, select FlexiFunnels as your trigger application within Pabbly Connect. You will then need to choose the event that will start the workflow, which is a new purchase.
Copy the provided webhook URL that Pabbly Connect generates for you. This URL will be used in your FlexiFunnels account to connect the two applications.
- Log into your FlexiFunnels account.
- Go to the product settings for the course you want to automate.
- Paste the webhook URL into the appropriate field and save your settings.
After saving, Pabbly Connect will wait for a response from FlexiFunnels to confirm that the connection is working correctly.
4. Enrolling the User in Thinkific
Once the trigger is set, the next step is to enroll the user in Thinkific. For this, you will choose Thinkific as your action application in Pabbly Connect.
Select the action event as ‘Create User’ first. You will need to connect your Thinkific account by entering your subdomain, which can be found in your account URL. After successfully connecting, you will need to map the user details from FlexiFunnels to Thinkific.
Map the first name, last name, and email address from the trigger data. Leave the password field blank, as users will set their password via email. Click ‘Send Test Request’ to verify that the user is created successfully.
After the test request, check your Thinkific account to confirm that the user has been created as expected.
5. Finalizing User Enrollment in Thinkific
After creating the user, the final step is to enroll them in the course. Again, select Thinkific as your action application and this time choose ‘Enroll User’ as the action event. using Pabbly Connect
Connect to your existing Thinkific account again and specify the course in which the user should be enrolled. Map the user ID dynamically so that it corresponds to the user created in the previous step.
Select the course, such as ‘Programming in Python’. Map the User ID obtained from the previous action step. Click ‘Send Test Request’ to enroll the user.
Once the test request is successful, verify in your Thinkific account that the user is now enrolled in the specified course. This completes the automation process, streamlining user enrollment through Pabbly Connect.
By leveraging Pabbly Connect, you can automate the enrollment of Thinkific users seamlessly whenever a purchase is made through FlexiFunnels. This integration not only saves time but also enhances the user experience by providing instant access to courses.
