Learn how to automate student enrollment in Thrive Card Learn Plus using Pabbly Connect and Instamojo. Step-by-step guide for seamless integration. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start automating the enrollment process, first, you need to access Pabbly Connect. Open a new tab in your browser and search for the Pabbly Connect website. Once there, you have the option to sign in or sign up for a free account if you are a new user.
If you choose to sign up, click on the ‘Sign Up for Free’ button, which will take just a couple of minutes. This gives you access to 100 tasks free every month. Existing users can simply sign in and navigate to the dashboard of Pabbly Connect.
After accessing the dashboard, the next step is to create a new workflow in Pabbly Connect. Click on the ‘Create Workflow’ button. A popup will appear where you need to name your workflow. For this task, name it something relevant, like ‘Enroll Students in Thrive Card Learn Plus on Instamojo Payments’.
- Select the folder where you want to save your workflow.
This will take you to the workflow setup page, where you will see two main boxes: Trigger and Action. The Trigger box is where you will set up the event that initiates the workflow, while the Action box is where you define what happens as a result.
3. Setting Up Trigger with Instamojo
The first step in your workflow is to set up the trigger. In this case, you will select Instamojo as your trigger application. Search for Instamojo and choose ‘Instamojo V1’. Next, you need to specify your trigger event, which will be ‘New Sale’.
To connect Instamojo with Pabbly Connect, you will need a webhook URL. Copy the provided webhook URL, which acts as a bridge between Instamojo and Pabbly Connect.
- Go to your Instamojo account and navigate to your product settings.
 - Paste the webhook URL in the appropriate field under Advanced Settings.
After saving the settings, return to Pabbly Connect, which will now be waiting for a response from Instamojo.
4. Testing the Integration with a New Sale
To test your integration, create a new sale for the product linked to your webhook. Go back to Instamojo, view your product, and click on ‘Buy Now’. Fill in the required customer details and complete the payment process.
Once the payment is successful, Pabbly Connect will receive a response containing details such as the buyer’s name, email, and payment status. Check the response in Pabbly Connect to ensure it shows a successful status.
Ensure you have received the correct status and details from Instamojo. If the status is ‘Credit’, you can proceed to the next step.
This successful response indicates that your integration is working correctly, and you are ready to set up the action step in Pabbly Connect.
5. Enrolling Students in Thrive Card Learn Plus
The final step is to enroll the student in Thrive Card Learn Plus using the information received from Instamojo. For this, select Thrive Card Learn Plus as your action application in Pabbly Connect. Choose the action event as ‘Create New Student’.
Connect Thrive Card Learn Plus with Pabbly Connect by entering the required API key, which you can generate from your Thrive Card Learn Plus account settings. Once connected, you will need to map the student details from the Instamojo response to the relevant fields in Thrive Card Learn Plus.
Map the email address, name, and course ID from the Instamojo response. Optionally, set up email notifications for the student.
Finally, click on ‘Save and Send Test Request’ to confirm the enrollment. Check your Thrive Card Learn Plus account to verify that the student has been enrolled successfully, completing the automation process.
In this tutorial, we demonstrated how to automate the enrollment of students in Thrive Card Learn Plus using Pabbly Connect and Instamojo. By following the steps outlined, you can streamline the enrollment process, saving time and enhancing the customer experience.
