Learn how to automate email responses using Pabbly Connect, AI Agent, and Gmail for smart communication. Step-by-step tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To automate email responses using Pabbly Connect, you first need to access the platform. Start by navigating to the Pabbly Connect homepage by typing the URL in your browser. You will see options to either sign in or sign up for free.
If you are a new user, click on the ‘Sign Up for Free’ button to create a new account. After signing up, you will receive 100 free tasks every month to explore the platform. Once logged in, you will be directed to the dashboard where you can manage your workflows.
After accessing your dashboard in Pabbly Connect, you can create a new workflow by clicking on the ‘Create Workflow’ option. A dialog box will appear prompting you to name your workflow. Name it ‘Automate Email Responses Using AI Agent for Smart Communication’.
  • Choose a relevant folder for your workflow.
  • Click on ‘Create’ to finalize your new workflow.
Once created, you will see a blank workflow screen where you can set up the trigger and actions for your automation. The trigger will be the event that starts the workflow, while the action will be the response to that trigger.
3. Setting Up the Trigger for JotForm
In this step, you will set up the trigger in Pabbly Connect for JotForm. Click on the trigger application option and select JotForm. Choose the event ‘New Response’ as your trigger event. This means that every time a new form is submitted in JotForm, the workflow will be activated.
To connect JotForm with Pabbly Connect, you will need to copy the webhook URL provided. This URL acts as a bridge for transferring data from JotForm to Pabbly Connect. After copying the URL, go to your JotForm account, navigate to the settings of your client inquiry form, and paste the webhook URL in the integration section.
4. Integrating AI Agent for Email Content Generation
Now that your JotForm is connected, the next step is to integrate your AI agent, which in this case is OpenAI, with Pabbly Connect. Choose OpenAI as your action application and select the event that allows you to generate content, such as ‘ChatGPT’. This action will create personalized email content based on the form responses.
When setting up the connection, you will need an API key from OpenAI. Go to your OpenAI account, create a new API key, and paste it into Pabbly Connect. After successful connection, specify the model you want to use, such as GPT-4, and provide a prompt that outlines the email content requirements.
  • Include details like full name, email, company name, and specific requirements in your prompt.
  • Ensure the output format is JSON for easy mapping in the next steps.
Once your prompt is set, test the action to ensure that the email content is generated correctly.
5. Sending Emails via Gmail
The final step in the automation process involves sending the generated email through Gmail using Pabbly Connect. Select Gmail as the action application and choose the ‘Send Email’ event. If you have an existing connection, you can use it; otherwise, create a new connection by logging into your Gmail account.
Map the email fields, including the recipient’s email address, subject, and email body, which you received from the previous OpenAI step. Once everything is set, click on ‘Save and Send Test Request’ to verify that the email is sent successfully. Check the recipient’s inbox to confirm the email has arrived.
With this setup, every time a new form is submitted in JotForm, a personalized email will be generated by OpenAI and sent through Gmail, automating your email responses efficiently using Pabbly Connect.
In summary, automating email responses using Pabbly Connect, AI Agent, and Gmail streamlines communication and enhances efficiency. By following these steps, you can ensure personalized engagement with leads effortlessly.
