Learn how to automate displaying your most selling WooCommerce products on Instagram using Pabbly Connect. Step-by-step tutorial for seamless integration. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
1. Setting Up Pabbly Connect for WooCommerce and Instagram Integration
To display your most selling WooCommerce products on Instagram, first, you need to set up Pabbly Connect. This powerful automation tool allows you to connect various applications seamlessly. Begin by signing up for a free account on Pabbly Connect’s landing page, which offers free automation tasks for testing.
Once registered, sign in to access your dashboard. Click on the ‘Create Workflow’ button to start setting up your automation. Name your workflow, such as ‘Display Most Selling Products on Instagram’, and click on the create button to proceed. This will open the workflow page where you can configure the trigger and action modules.
2. Configuring the Workflow Trigger in Pabbly Connect
The first step in your automation process is to configure the trigger. In this case, you will use the scheduler feature of Pabbly Connect to determine how frequently you want to display your products. You can select various scheduling options, such as daily, weekly, or monthly.
- Choose the frequency of the workflow execution (e.g., every first of the month).
- Set the specific time for the workflow to run (e.g., 12 PM).
After selecting your preferred options, save the settings. This configuration allows Pabbly Connect to automatically run your workflow at the specified intervals, ensuring that your most selling products are displayed on Instagram without manual intervention.
3. Connecting WooCommerce to Pabbly Connect
Next, you will need to connect your WooCommerce store to Pabbly Connect to fetch product details. In the action step, select WooCommerce and choose the ‘Get All Products’ action event. Connect your WooCommerce account by providing the consumer key, consumer secret, and website URL, which can be found in the REST API section of your WooCommerce settings.
To generate the API keys, go to your WordPress dashboard, navigate to WooCommerce > Settings > Advanced > REST API, and click on ‘Add Key’. Fill in the description and set permissions to ‘Read/Write’. After generating the API keys, copy and paste them into Pabbly Connect along with your website URL (without a trailing slash).
4. Filtering Most Selling Products with Pabbly Connect
Once you have connected WooCommerce, the next step is to filter the products to display only the most selling ones. In Pabbly Connect, use the Iterator feature to segregate the product details one by one. This allows you to process each product individually, starting from the first.
- Select the product array from the previous step.
- Apply a filter to only include products with sales greater than 100.
By setting this condition, Pabbly Connect will only proceed with products that have met the sales threshold, ensuring that only the most popular items are shared on Instagram.
5. Creating and Sharing Displayable Images on Instagram
After filtering the products, you can create a displayable image using the Switchboard Canvas application integrated through Pabbly Connect. Start by selecting the ‘Create Image’ action event in Switchboard Canvas. Connect your account using the API key provided in your Switchboard Canvas account settings.
Map the necessary fields, including the product image link and product name, to generate a visually appealing image. Finally, use the Instagram for Business integration in Pabbly Connect to publish the created image. Connect your Instagram account and specify the photo URL along with an engaging caption or hashtags.
By following these steps, you can automate the process of displaying your most selling WooCommerce products on Instagram, saving time and enhancing your marketing efforts.
In conclusion, using Pabbly Connect, you can effectively automate the display of your most selling WooCommerce products on Instagram, ensuring consistent promotional efforts without manual input. This integration not only saves time but also helps in efficiently managing your marketing strategies.
