Learn how to automate ClickFunnels contacts from LinkedIn Lead Gen Forms using Pabbly Connect. Step-by-step tutorial for seamless integration. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start automating the process of creating ClickFunnels contacts from LinkedIn Lead Gen Forms leads, you will need to access Pabbly Connect. Begin by visiting the Pabbly Connect website and signing in to your account. If you are a new user, you can sign up for free and explore the platform with 100 tasks each month.
Once signed in, you will see various applications offered by Pabbly. Click on the ‘Access Now’ button for Pabbly Connect to open your dashboard. From here, you can create a new workflow, which will facilitate the integration between LinkedIn and ClickFunnels.
In this step, you will create a new workflow in Pabbly Connect for the automation process. Click on the ‘Create Workflow’ button, and you will be prompted to name your workflow. Name it as ‘Create ClickFunnels Contact from LinkedIn Lead Gen Forms Leads’ and select the appropriate folder for organization.
- This opens the workflow window where you can set up triggers and actions.
In this workflow, you will set LinkedIn Lead Gen Forms as the trigger application, which will initiate the process whenever a new lead is generated. This allows for seamless automation and eliminates the need for manual data entry into ClickFunnels.
3. Setting Up the Trigger: LinkedIn Lead Gen Forms
Now, select LinkedIn Lead Gen Forms as your trigger application in Pabbly Connect. Choose the trigger event as ‘New Lead Form Response’ to capture leads from your LinkedIn forms. Click on the ‘Connect’ button to establish this connection.
If you have not previously connected your LinkedIn account, click on ‘Add New Connection’ and follow the prompts to sign in. Once connected, select your LinkedIn account and the specific lead form you wish to use for this automation.
- Make sure to click ‘Save and Send Test Request’ to test the connection.
- Pabbly Connect will pull the latest lead information for verification.
By following these steps, you ensure that your LinkedIn leads are effectively captured and prepared for the next stage of the automation process.
4. Setting Up the Action: Creating ClickFunnels Contact
In this section, you will set ClickFunnels as the action application in Pabbly Connect. Select ‘ClickFunnels’ and choose the action event as ‘Create Contact’. This will allow you to automatically add new leads from LinkedIn to your ClickFunnels account.
Click on the ‘Connect’ button and, similar to the previous step, either select an existing connection or add a new one. To connect, you will need your API access token and subdomain from ClickFunnels. Navigate to your ClickFunnels account settings to retrieve this information.
Go to Team Settings in ClickFunnels and then to the Developer Portal. Create a new platform for LinkedIn and copy the API token provided.
After entering the API token and subdomain in Pabbly Connect, click ‘Save’. This will establish the connection between ClickFunnels and Pabbly Connect, allowing the automation to proceed.
5. Mapping Fields for Automation
Once the connection is established, the next step in Pabbly Connect is to map the fields from your LinkedIn Lead Gen Forms to ClickFunnels. This is crucial for ensuring that the correct data is transferred automatically.
In the mapping section, you will see fields for email address, first name, last name, and phone number. Use the mapping feature to pull data from the LinkedIn lead response directly into these fields. This allows for dynamic data transfer each time a new lead is generated.
Select the corresponding fields from the LinkedIn response for mapping. Click on ‘Save and Send Test Request’ to verify that the contact is created successfully in ClickFunnels.
When you check your ClickFunnels account, you will see that a new contact has been created with the information from your LinkedIn lead. This confirms that the automation is functioning correctly, and new leads will be added automatically from LinkedIn to ClickFunnels without any manual intervention.
By following this tutorial, you can effectively automate the process of creating ClickFunnels contacts from LinkedIn Lead Gen Forms using Pabbly Connect. This integration not only saves time but also ensures that your leads are promptly added to your marketing funnel for better follow-up and nurturing.
Utilizing Pabbly Connect for this automation enhances your workflow efficiency, allowing you to focus on other important aspects of your business. Start leveraging this powerful integration today!
