Learn how to auto-generate blog posts for Blogger using Pabbly Connect and AI Agent. Follow this step-by-step tutorial for seamless integration. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
To start automating blog post generation, access Pabbly Connect by visiting the official website. If you are a new user, you can sign up for a free account, which offers 100 free tasks each month. Existing users can sign in directly to their Pabbly Connect dashboard.
Once logged in, you will see the Pabbly Connect dashboard. Click on the ‘Create Workflow’ button to initiate the setup. You will be prompted to name your workflow, which can be something like ‘AI Agent to Auto-Generate Blog Posts for Blogger’. After naming, select the folder to save your workflow and click on ‘Create’.
2. Setting Up Google Sheets as a Trigger in Pabbly Connect
In this section, we will set Google Sheets as the trigger application in Pabbly Connect. This means that whenever a new row is added or updated in your Google Sheets, it will trigger the automation process. Select Google Sheets as your trigger application.
- Choose ‘New or Updated Spreadsheet Row’ as the trigger event.
- Copy the provided webhook URL from Pabbly Connect.
- Open your Google Sheets, go to Extensions > Add-ons > Get Add-ons, and search for Pabbly Connect Webhooks to install it.
After installation, refresh your spreadsheet, then go back to Extensions > Pabbly Connect Webhooks > Initial Setup. Paste the webhook URL and set the trigger column (e.g., Column F) where you will input data. Click ‘Submit’ to complete the setup.
3. Connecting the AI Agent for Content Generation
Next, we will connect an AI agent (like OpenAI) to generate blog content based on the input from Google Sheets. In Pabbly Connect, select OpenAI as the action application. Choose ‘ChatGPT’ as the action event.
Click ‘Connect’ and then ‘Add New Connection’. You will need to provide the API token from your OpenAI account. After entering the token, select the AI model you wish to use, such as GPT-4 Mini.
- In the prompt field, specify the requirements for the blog post, including tone, keywords, and formatting.
- Map the fields from the previous step to ensure the AI generates content based on the correct data.
After mapping the data, click ‘Save and Send Test Request’ to generate the blog content. The AI will provide a response containing the generated blog post.
4. Creating a Blog Post on Google Blogger
Once the blog content is generated, the next step is to create a new post on Google Blogger using Pabbly Connect. Select Google Blogger as the action application and choose ‘Create a Post’ as the action event.
Connect to your Google Blogger account by selecting the appropriate account and authorizing Pabbly Connect. Map the title and content fields using the data received from the AI agent. Set the post status to draft to allow for any necessary edits before publishing.
Select the blog ID where the post will be published. Map the content generated by the AI agent into the content field. Click ‘Save and Send Test Request’ to create the post.
After the test request, check your Google Blogger account to see if the post has been created successfully.
5. Updating Blog Status in Google Sheets
Finally, we need to update the blog status in your Google Sheets to reflect that the post has been created. In Pabbly Connect, add another action step and select Google Sheets as the application. Choose ‘Update Row’ as the action event.
Map the necessary fields to update the status column in your spreadsheet. Set the status to ‘Created’ to indicate that the blog post has been successfully published.
Select the spreadsheet and sheet where the blog content is stored. Map the row index to ensure the correct row is updated.
Click ‘Save and Send Test Request’ to complete the update. Now, your Google Sheets will reflect the new status of the blog post.
Using Pabbly Connect, you can seamlessly automate the process of generating and posting blog content on Blogger. By integrating Google Sheets, an AI agent, and Google Blogger, you can save time and enhance your blogging efficiency. This setup allows for easy updates and management of your blog posts, ensuring your audience stays engaged with fresh content.
